[GRASS-dev] Re: [GRASS-user] GRASS6.3 on Windows, nviz
Michael Barton
michael.barton at asu.edu
Sat Aug 25 10:55:43 EDT 2007
Helena,
If you can tell me where this is in all the NVIZ code, I'll take a look at
it.
Michael
On 8/24/07 2:06 PM, "Helena Mitasova" <hmitaso at unity.ncsu.edu> wrote:
> On Thu, 2007-08-23 at 23:15 -0700, Michael Barton wrote:
>> I've gone through and wrapped in catch statements all GRASS commands worth
>> wrapping (and probably some not worth it).
>> I also did a bit of cleanup to the help routines that I ran across.
>> I also added Carlos' get info buttons to the raster and vector layer panels.
>> These are quite handy.
>> There is a bug in v.what such that it kicks out the wrong stuff with its GUI
>> interface description. Only shows up from the GUI, but it would be nice if
>> it could be fixed.
>> Anything else GUI-wise broken and fixable that anyone has noticed?
> There still seems to be a nviz GUI redesign related problem
> (it may be due to my set up, but Paul said
> that he has a problem with Save state on his freshly checked GRASS CVS
> too.)
> I have compared nviz in 6.2.1 that had older interface and Save State
> works there (at least to some extent) with 6.3 and the state
> files are indeed different - in 6.3 the light data are missing and the
> order of saved settings is different (the later may not matter).
> But the real problem is that nviz in 6.3
> cannot read the saved settings and I get the following error:
> Diagnostic: wrong # args: should be "set varName ?newValue?" -- Load
> procedure for panel main may not be defined
> Diagnostic: invalid command name "Nviz_720 752_load" -- Load procedure
> for panel 720 752 may not be defined
> Diagnostic: invalid command name "Nviz_22.0_load" -- Load procedure for
> panel 22.0 may not be defined
> Diagnostic: invalid command name "Nviz_4.462_load" -- Load procedure
> for panel 4.462 may not be defined
> Diagnostic: invalid command name "Nviz_379.50_load" -- Load procedure
> for panel 379.50 may not be defined
> Diagnostic: invalid command name "Nviz_0.504 0.984_load" -- Load
> procedure for panel 0.504 0.984 may not be defined
> Diagnostic: invalid command name "Nviz_1_load" -- Load procedure for
> panel 1 may not be defined
> Diagnostic: invalid command name "Nviz_234.500000 234.500000
> 120.363991_load" -- Load procedure for panel 234.500000 234.500000
> 120.363991 may not be defined
> There is also a problem with scripts - I don't think it is directly in
> the file sequencing tool as I assume that it has not been touched, but
> some of the recent changes must have affected handling of map names:
> section of nviz script created by file sequencing tool
> old that worked:
> if {$iloop4 < 8} then {
> if {[lsearch {} $iloop4] == -1} then {
> if {[lsearch {} $iloop4] > -1} then {
> SendScriptLine "lappend NVIZ_BLANK_MAPS [ExtractMapID $mhandle6]"
> } else {
> SendScriptLine "$mhandle6 set_att color [lindex {hfl.sig100 at indyfi
> hfl.sig10 at indyfi hfl.sig1 at indyfi hfl.sig05 at indyfi hfl.sig03 at indyfi
> hfl.sig01 at indyfi hfl.sig005 at indyfi hfl.sig001 at indyfi} $iloop4]"
> new that does not work for obvious reasons (full path instead of
> rastername at mapset) :
> if {$iloop3 < 1} then {
> if {[lsearch {} $iloop3] == -1} then {
> if {[lsearch {} $iloop3] > -1} then {
> SendScriptLine "lappend NVIZ_BLANK_MAPS [ExtractMapID $mhandle4]"
> } else {
> SendScriptLine "$mhandle4 set_att topo [lindex
> {/local/home/helena/grassdata07/nc_spm_05/user1/cell/elev_lidtopandef_1m at user1
> } $iloop3]"
> The reason for the above problem seems to be that the save fields
> function saves full path instead of name at mapset
> /local/home/helena/limg/grassbook/dynsurf.state.nviz
> 2
> Surface
> Topography
> surf*1185562518
> 1
> Surface
> Color
> surf*1185562518
> 5
> /local/home/helena/grassdata07/nc_spm_05/user1/cell/distr_2m.0418 at user1
> /local/home/helena/grassdata07/nc_spm_05/user1/cell/distr_2m.0438 at user1
> /local/home/helena/grassdata07/nc_spm_05/user1/cell/distr_2m.0458 at user1
> /local/home/helena/grassdata07/nc_spm_05/user1/cell/distr_2m.0478 at user1
> /local/home/helena/grassdata07/nc_spm_05/user1/cell/distr_2m.0498 at user1
> the old field file has just
> I am hoping that the fix is not too complex,
> Helena
>> Michael
>> On 8/22/07 4:22 AM, "Paul Kelly" <paul-grass at stjohnspoint.co.uk> wrote:
>>>>> A couple of side-notes though:
>>>>> 1) In general the GUI is terrible at catching and reporting errors from
>>>>> modules it calls in the background and this leads to cryptic error
>>>>> messages or nothing happening all over the place. IMHO it is a really
>>>>> pervasive problem that definitely needs fixed in the next GUI. Hopefully
>>>>> it already is there (ISTR discussions about every call to a GRASS module
>>>>> going through some other function where the error trapping could
>>>>> presumably be added, to avoid code repetition).
>>>> Actually, error trapping is pretty good in the GUI now, except for NVIZ
>>>> (but
>>>> which doesn't run much in the way of GRASS commands anyway). There are
>>>> traps
>>> Well maybe I was being a bit overly dramatic, but running
>>> grep "exec " *.tcl | grep -v catch | wc -l
>>> in the gis.m directory still reveals 72 lines where exec is used without a
>>> corresponding catch. Not very scientific and perhaps not important in most
>>> cases - but if a single command (be it a GRASS module or system command)
>>> is not available or not working for some reason it could really make the
>>> difference between somebody tearing their hair out for a day or finding
>>> the source of a problem quickly.
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> Director of Graduate Studies
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
phone: 480-965-6213
fax: 480-965-7671
