[GRASS-dev] [grass-code I][470] i.atcorr: hardcoded input/output map names
grass-dev at grass.itc.it grass-dev at grass.itc.it
Mon Aug 27 16:41:17 EDT 2007
code I item #470, was opened at 2007-08-27 22:41
Status: Open
Priority: 3
Submitted By: Maciej Sieczka (msieczka)
Assigned to: Nobody (None)
Summary: i.atcorr: hardcoded input/output map names
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: imagery
Operating system: None
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD): 070827
Initial Comment:
i.atcorr has a follwoing set of map names hardcoded:
iimg=ETM4_400x400.raw
ialt=dem_float
ivis=visibility
icnd=ETM4_atmospheric_input_GRASS.txt
oimg=6s_output_file
Shouldn't have any.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=470&group_id=21
