[GRASS-dev] [grass-code I][470] i.atcorr: hardcoded input/output
map names
Yann
yann.chemin at gmail.com
Tue Aug 28 13:16:09 EDT 2007
Yes, this is test data, was in testdata/ dir in the grassSVN Add-ons before
joining CVS.
Please anyone with write access may change this.
Yann
On Tuesday 28 August 2007 03:41:17 grass-dev at grass.itc.it wrote:
> code I item #470, was opened at 2007-08-27 22:41
> Status: Open
> Priority: 3
> Submitted By: Maciej Sieczka (msieczka)
> Assigned to: Nobody (None)
> Summary: i.atcorr: hardcoded input/output map names
> Issue type: module bug
> Issue status: None
> GRASS version: CVS HEAD
> GRASS component: imagery
> Operating system: None
> Operating system version:
> GRASS CVS checkout date, if applies (YYMMDD): 070827
> Initial Comment:
> i.atcorr has a follwoing set of map names hardcoded:
> iimg=ETM4_400x400.raw
> ialt=dem_float
> ivis=visibility
> icnd=ETM4_atmospheric_input_GRASS.txt
> oimg=6s_output_file
> Shouldn't have any.
> You can respond by visiting:
> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=470&group_id=2
>1
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
Yann Chemin
http://airdensity.hi5.com/
Sainte-Anne d'Auray, France
