[GRASS-dev] [grass-code I][470] i.atcorr: hardcoded input/output
map names
Yann
yann.chemin at gmail.com
Wed Aug 29 14:16:34 EDT 2007
Hi Maciek:
Line 221-222 in main.cpp:
ialt_fd: height map file descriptor, negative if global value is used
ivis_fd: visibility map file descriptor, negative if global value is used
Yann
On Wednesday 29 August 2007 01:27:46 Maciej Sieczka wrote:
> Also, please explain if/how the elevation and visibility rasters (ialt
> and ivis) interefere with the target elevation and visibility
> parameters in the icnd configuration file. For example, if I use ialt
> raster, do I still have to/must not provide the target elevation in the
> config file?
> Maciek
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Yann Chemin
http://airdensity.hi5.com/
Sainte-Anne d'Auray, France
