[GRASS-dev] [grass-code I][470] i.atcorr: hardcoded input/output
map names
Yann
yann.chemin at gmail.com
Wed Aug 29 16:40:19 EDT 2007
If using a global value in the configuration file, then it is overiding the
corresponding input map.
I have not yet found a clear explaination on what to do in the config file to
read the map directly. Careful though, since reading input maps will run 6s
for each pixel (0.5-1s/pixel can be a long time for a Landsat image to
process).
Using global values from config file will run 6s once and apply an affine
transform on all the image. Fast and OK for a small area.
trade-off...
On Thursday 30 August 2007 02:49:13 Maciej Sieczka wrote:
> Yann wrote:
> > Hi Maciek:
> > Line 221-222 in main.cpp:
> > ialt_fd: height map file descriptor, negative if global value is
> > used ivis_fd: visibility map file descriptor, negative if global
> > value is used
> Yann,
> Thanks. I don't know C. I'm no programmer. Can you please say which one
> - the raster or the value in the i.attcor config file takes precedence?
> What happens if both are specified?
> Maciek
Yann Chemin
http://airdensity.hi5.com/
Sainte-Anne d'Auray, France
