[GRASS-dev] [grass-code I][470] i.atcorr: hardcoded
input/output map names
Brad Douglas
rez at touchofmadness.com
Thu Aug 30 05:39:01 EDT 2007
I started working on this awhile ago after realizing values were
hardcoded, etc. IIRC, I didn't finish because it was becoming
complicated and I didn't have time to dedicate to it.
I can commit what I have (and comment unfinished code) if someone wants
to have it done relatively quickly and is willing to finish it
themselves.
Until then, I think it should probably be removed from the Makefile.
On Wed, 2007-08-29 at 00:16 +0700, Yann wrote:
> Yes, this is test data, was in testdata/ dir in the grassSVN Add-ons before
> joining CVS.
> Please anyone with write access may change this.
> Yann
> On Tuesday 28 August 2007 03:41:17 grass-dev at grass.itc.it wrote:
> > code I item #470, was opened at 2007-08-27 22:41
> > Status: Open
> > Priority: 3
> > Submitted By: Maciej Sieczka (msieczka)
> > Assigned to: Nobody (None)
> > Summary: i.atcorr: hardcoded input/output map names
> > Issue type: module bug
> > Issue status: None
> > GRASS version: CVS HEAD
> > GRASS component: imagery
> > Operating system: None
> > Operating system version:
> > GRASS CVS checkout date, if applies (YYMMDD): 070827
> > Initial Comment:
> > i.atcorr has a follwoing set of map names hardcoded:
> > iimg=ETM4_400x400.raw
> > ialt=dem_float
> > ivis=visibility
> > icnd=ETM4_atmospheric_input_GRASS.txt
> > oimg=6s_output_file
> > Shouldn't have any.
73, de Brad KB8UYR/6 <rez touchofmadness com>
