[GRASS-dev] [grass-doc I][559] man r.in.gdal
grass-dev at lists.osgeo.org
Fri Dec 7 12:38:46 EST 2007
doc I item #559, was opened at 2007-12-07 17:38
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: man r.in.gdal
Issue status: None
Doc section: None
GRASS version: None
Doc timestamp (YYMMDD):
Initial Comment:
When I do man r.in.gdal within the (GRASS-)terminal, the "GDAL supported raster formats" section is not easily readable... (does not look like a table).
Is it possible to force it to to look like a table?
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=207&aid=559&group_id=21
