[GRASS-dev] [grass-doc I][559] man r.in.gdal
Glynn Clements
glynn at gclements.plus.com
Sat Dec 8 07:44:31 EST 2007
grass-dev at lists.osgeo.org wrote:
> doc I item #559, was opened at 2007-12-07 17:38
> Status: Open
> Priority: 3
> Submitted By: Nikos Alexandris (nikosa)
> Assigned to: Nobody (None)
> Summary: man r.in.gdal
> Issue status: None
> Doc section: None
> GRASS version: None
> Doc timestamp (YYMMDD):
> Initial Comment:
> When I do man r.in.gdal within the (GRASS-)terminal, the "GDAL
> supported raster formats" section is not easily readable... (does not
> look like a table).
> Is it possible to force it to to look like a table?
Although g.html2man attempts to convert tables, it clearly doesn't
work. Consequently, raster/r.in.gdal/description.html should be
changed to use pre-formatted text instead of an HTML table.
