[GRASS-dev] [grass-code I][561] configure check for blas/lapack in
OSX veclib framework should not depend on MACOSX_APP
grass-dev at lists.osgeo.org
Sat Dec 8 13:11:58 EST 2007
code I item #561, was opened at 2007-12-08 12:11
Status: Open
Priority: 3
Submitted By: William Kyngesburye (kyngchaos)
Assigned to: Nobody (None)
Summary: configure check for blas/lapack in OSX veclib framework should not depend on MACOSX_APP
Issue type: other bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: build
Operating system: MacOS X
Operating system version: any
GRASS CVS checkout date, if applies (YYMMDD): RC3
Initial Comment:
The presence of the OSX veclib framework for blas/lapack has nothing to do with building the OSX application. The veclib framework can be used in a unix build on OSX as well.
It should rather test for the framework blindly and let it fail on other systems.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=561&group_id=21
