[GRASS-dev] [grass-code R][562] add support for libedit substitute for readline/history
Sun Dec 9 16:12:42 EST 2007
grass-dev at lists.osgeo.org wrote:
> code R item #562, was opened at 2007-12-08 23:38
> Status: Open
> Priority: 2
> Submitted By: William Kyngesburye (kyngchaos)
> Assigned to: Nobody (None)
> Summary: add support for libedit substitute for readline/history
> Issue status: None
> GRASS component: GRASS wide
> Operating system: MacOS X
> Operating system version:
> Initial Comment:
> libedit is included in OSX, so is more convenient. There is a symlink
> to libreadline, but none for libhistory, so the check for readline
> support in configure fails.
To be honest, I don't see any point in having the readline support in
the first place. If the expression is complex enough to warrant the
use of readline, you should probably enter it into a text file using
your preferred text editor then use e.g. "r.mapcalc < myscript".
