[GRASS-dev] Some migration news
Martin Landa
landa.martin at gmail.com
Mon Dec 10 17:23:07 EST 2007
2007/12/10, Maciej Sieczka <tutey at o2.pl>:
> Martin Landa wrote:
> > But the export from GForge failed
> How did you do this "export"?
this URL should generate XML file with tickets definition of the given
group (atid=188) (which can be used as an input for
sourceforge2trac.py script)
http://wald.intevation.org/export/tracker.php?atid=188&group_id=21
but it is generating invalid, almost empty file...
Martin
> If all goes well we'll get an SQL dump of GRASS GForge
> trackers content from Sascha. Would it be easy to import
> this into Trac?
> Maciek
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
