[GRASS-dev] GRASS CVS to SVN migration: repository structure
Tue Dec 11 09:55:06 EST 2007
Hamish wrote:
> > > I'm unclear on how further 6.x development is to be handled.
> > > In the medium term, I would expect there to be futher development on
> > > 6.x culminating in a 6.4 release. This will need to occur on a
> > > separate branch to 7.x. E.g.:
> > >         +----+----> 7.x-devel
> > >              +----+----+--------> 6.x-devel
> > >                   |    +----> 6.4-release
> > >                   +----> 6.3-release
> > > The 6.x-devel and 6.3-release branches would be created immediately,
> > > with 6.4-release created once 6.x-devel has accumulated changes which
> > > cannot go into the 6.3.x releases.
> > > The trunk would become 7.x-devel, and would quickly change to the
> > > point that merging changes with 6.x-devel would become impractical.
> Martin wrote:
> > proposal...
> > +--+-----+-----> 7.x-devel (trunk)
> > |    |      +------> 6.4-release (branch) <--- should be created [ASAP]
> > |    |          | backports (6.4 -> 6.3)
> > |    +-------------> 6.3-release (branch)
> I much prefer Glynn's proposal.
> 6.3.0 release branch is not meant to be a stable branch. We can fix bugs in it,
> but if its purpose is to help get the MS Windows stuff tested, then that's a
> lot of backporting from 6.x/HEAD when we get ready for 6.3.1. (or just make
> 6.3.1 a new branch from 6.x/HEAD). I consider it like 6.1.0, ie a dead-end
> preview release.
There may be some confusion with terminology. Currently, we have the
6.2-release branch (releasebranch_6_2), the 6.3-release branch
(releasebranch_6_3) and the trunk serving as 6.x-devel.
I'm proposing that we immediately create branches for 6.3-release and
6.x-devel, with a 6.4-release branch eventually being created as a
branch of 6.x-devel.
IOW, we need both 6.x and 7.x development branches (one of which would
be the trunk), in addition to any release branches. We don't need a
6.4 release branch yet.
> 6.4 requires a stable wxGUI, this isn't going to happen instantly. Porting
> everything from 6.x/HEAD back into the 6.4 r.b. for months seems like a huge
> waste of effort. Thus I think creating a 6.4 release branch ASAP is a mistake.
> Let's do it when the code it ready.
> There should be no need to port stuff back to 6.3 r.b. once we have a 6.4 r.b.
> >From then on we call the new preview releases 6.4beta1, etc. and forget 6.3.
> We will need some strong discipline to put all new development into 7.x/HEAD
> and backport interesting things to 6.x/HEAD; not the other way around.
Backporting from 7.x to 6.x is likely to be somewhere between hard and
impossible, hence the need to maintain a 6.x-devel branch for the
medium term.
One of the first things which I want to do for 7.x is to globally
re-format all code to a common convention. That alone will cause
problems with merging.
