[GRASS-dev] [grass-code I][565] i.smap fails because it can't find
subgroup (?)
grass-dev at lists.osgeo.org
Fri Dec 14 21:10:23 EST 2007
code I item #565, was opened at 2007-12-15 02:10
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: i.smap fails because it can't find subgroup (?)
Issue type: None
Issue status: None
GRASS version: CVS HEAD
GRASS component: imagery
Operating system: Linux
Operating system version: Ubuntu 7.10
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
[I have already posted a question in the user-list about that...]
I do following in GRASS6.2.3 (from Ubuntu repositories):
> i.smap group=Change_PCA subgroup=Change_PCAsub signaturefile=Training_iSMAPsig blocksize=128 output=TESTGRASS623
Processing rows 1-128 (of 1087), cols=1-128 (of 963)
Processing rows 1-128 (of 1087), cols=129-256 (of 963)
Processing rows 1-128 (of 1087), cols=257-384 (of 963)
Writing [TESTGRASS6.2.3] ...
100%
[Raster MASK present]
Using the same data in GRASS6.3.cvs (fresh updated, compiled, installed) I get:
> i.smap group=Change_PCA at nik subgroup=Change_PCAsub at nik signaturefile=Training_iSMAPsig blocksize=128 output=TEST_GRASS63cvs
ERROR: Subgroup [Change_PCAsub at nik] not found.
Where could be the error?
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=565&group_id=21
