[GRASS-dev] r.colors "-e" not going to full range
Hamish
hamish_b at yahoo.com
Mon Dec 17 21:44:23 EST 2007
> Hamish wrote:
> > I just created a v.surf.rst elevation surface from some point data
> > which has a few negative values in it. After creating the surface I
> > set the colors with 'r.colors -e color=bcyr'. It looks really nice
> > but there are white holes in the d.rast display.
> > r.info -r shows:
> > min=-1.510814
> > max=146.157700
> > The colr/ file doesn't go to one integer beyond the full range:
> > % -1 145
> > nv:255
> > *:255
> > -1:0:0:255 0:0:94:255
> > 144:255:1:0 145:255:1:0
Glynn:
> I didn't realise that "r.colors -e" even worked on FP data;
> "r.colors color=grey.eq" doesn't.
> Ultimately, the code is dependent upon the categories returned by
> G_next_cell_stat(). If it only returns up to category 145, then the
> colour table will only extend to that value.
> > min=-1.510814
> > max=146.157700
> > % -1 145
I could assume the -1.51 -> -1 problem was due to a cast to CELL when
using a FP map with "*_cell_stat". The 146.15 vs 145 is a bit weirder,
cast + missing the last iteration? No idea how to make it extend to be
"% -2 147" for FP maps with G_next_cell_stat().
> > I also noticed for another map 'r.colors -e' made a massive and slow
> > colr/ file (1 for each cat) when the raster values were +-250000. That
> > was a diff map centered on zero and I was using r.colors.stddev (wiki
> > addons) to set the colors. While it had those huge outliers 95% of the
> > points were +-5 (hence using the -e flag to get useful colors). It
> > took impossibly long to render of course, so I looked in the colr/
> > file and discovered it was huge.
> > Ok, maybe that's a feature of the -e method. But what I saw that was
> > interesting was that between -265000 and -120 all the R:G:B values
> > were identical, ie all those thousands and thousands of rules could
> > have been condensed into a single "-265000:R:G:B -120:R:G:B". And
> > that a little program to do that would probably be trivial. I am a
> > bit unsure if that condensing should happen as a addon script which
> > reprocesses the file, when the colr/ file is created by 'r.colors
> > -e', or when the color rules are read in upon d.rast. (or some
> > combination of the above) It would seem like a nice enhancement to
> > have that happen though.
> > I notice that even in my current -1.5 thru 146m map '-e' produces
> > some redundant entries.
> Can you test the attached patch?
for a random lidar test map, the colr/ file is 21349 lines long unpatched
and 1497 lines long patched. Nice. There is still room for improvement
though:
[color_xform.c unpatched]
% -14900 1462400
nv:255
*:255
-14900:0:0:255 -14100:0:0:255
-14100:0:0:255 -14000:0:0:255
-14000:0:0:255 -13800:0:0:255
-13800:0:0:255 -13700:0:0:255
-13700:0:0:255 -13600:0:0:255
-13600:0:0:255 -13400:0:0:255
-13400:0:0:255 -13300:0:0:255
-13300:0:0:255 -13200:0:0:255
-13200:0:0:255 -13100:0:0:255
-13100:0:0:255 -13000:0:0:255
-13000:0:0:255 -12900:0:0:255
[color_xform.c patched]
% -14900 1462400
nv:255
*:25
-14900:0:0:255 -10500:0:0:255
-10500:0:0:255 -10400:0:1:255
-10400:0:1:255 -9800:0:1:255
-9800:0:1:255 -9750:0:2:255
-9750:0:2:255 -9350:0:2:255
-9350:0:2:255 -9300:0:3:255
-9300:0:3:255 -9000:0:3:255
-9000:0:3:255 -8950:0:4:255
-8950:0:4:255 -8700:0:4:255
-8700:0:4:255 -8650:0:5:255
-8650:0:5:255 -8450:0:5:255
-8450:0:5:255 -8400:0:6:255
-8400:0:6:255 -8300:0:6:255
-8300:0:6:255 -8200:0:7:255
-8200:0:7:255 -8050:0:7:255
-8050:0:7:255 -8000:0:8:255
-8000:0:8:255 -7900:0:8:255
-7900:0:8:255 -7850:0:9:255
-7850:0:9:255 -7700:0:9:255
it seems that every second line is redundant.
aside: I hadn't noticed the *:color [undefined, does this correspond to
"default" in G_parse_color_rule()?], invert, and shift:n colr/ rules
abilities before. invert is now covered by the r.colors -n flag using
another method, is 'shift' of any use?
Hamish
