[GRASS-dev] things to do before the 6.3.0 release
Hamish
hamish_b at yahoo.com
Wed Dec 19 21:47:32 EST 2007
Ha:
> > > > Also, "l" in XDRIVER fill is badly broken.
Gl:
> Duh; I spent about two hours looking over the culling algorithm
> before noticing that the problem with "l" is due to overflowing
> X's 16-coordinate range (16-bit signed short: -32768 to 32767).
> That issue effectively rules out using "l" so long as XDRIVER exists.
> I'll leave the code there for 7.x.
oh well. good to find this out before we went too far with it I guess.
Ha:
> > > > next problem- r,d inverse fill a small bay upon zoom in.
Gl:
> I can't reproduce the inversion with r/d and the PNG driver (using
> r/d with XDRIVER kills Cygwin's X server), but it might be sensitive
> to the region. Can you provide a region where this occurs?
region the same as in my render_trial_area_fill.sh,
g.region n=5528100 s=5526600 w=2053900 e=2055400 res=100
but I only see it after running d.resize*:
d.resize w=1200 h=1350
the initial 400x300 window doesn't show it. (a sixth of 800x900)
export GRASS_WIDTH=800
export GRASS_HEIGHT=900
d.mon x1
# split display into six frames (from wiki addons)
d.frame.quarter -6
[*] d.resize: I've given up on bloaty dumbed-down GNOME and never liked
the look of KDE, so I've gone back to using the fluxbox WM. There xmons
can not be resized by dragging on a corner for some reason. I've never
noticed this for any other X app, which makes me wonder if it is xmon
specific after all. We discussed this some time ago:
http://thread.gmane.org/gmane.comp.gis.grass.devel/8709/
but this is another matter, and rather low priority.
ok, after a little d.zoom'ing I got it to invert, both XDRIVER and PNG
driver, both 'd' and 'r' methods.
g.region n=5527800 s=5526900 w=2054700 e=2055300 res=100
export GRASS_WIDTH=600
export GRASS_HEIGHT=338
d.mon x1
METHOD=d
d.vect Coast_isl_fj render=$METHOD
Another thing I now notice, which I can replicate with 'd' and 'r', is
area fill is not happening for some islands. (Both PNG and XDRIVER)
See attached. If 'd.vect type=area' all the islands on the left are
missing. (but the ones in the middle are ok)
g.region n=5541800 s=5513200 w=2035900 e=2072600 res=100
d.mon x1
METHOD=d
TEXT="`echo $METHOD | tr '[:lower:]' '[:upper:]'`"
d.text text="$TEXT" color=black -b at=99,99 align=ur
Ha:
> > how about 'c' as the default for the 6.3.0 release then?
> > (if PNG driver boundary/fill line-up problem can be fixed)
Gl:
> It looks like it's going to have to be "c". r, d and l all risk
> passing out-of-range coordinates to XDRIVER, which will produce
> complete garbage and may even kill the X server.
ouch.
I take it there is some reason the Xdriver can't contain some sort of
bounds checking {if(x > xmax) x=xmax;}, I assume you would have already
done that if it were possible... :)
thanks,
Hamish
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Type: image/png
Desc: 1226526865-dvect_render_d_nofill.png
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20071219/492b1266/dvect_render_d_nofill-0001.png
