[GRASS-dev] [grass-code I][566] g.rename fails to rename maps
Glynn Clements
glynn at gclements.plus.com
Fri Dec 21 16:06:54 EST 2007
Moritz Lennert wrote:
> >>> It's in manage:
> >>> http://trac.osgeo.org/grass/browser/grass/trunk/general/manage/cmd
> >>> Moritz
> >> Thanks for the pointer. Is it still a bug, though? Can anyone confirm?
> > Yup. It's due to line 28 in /general/manage/lib/do_rename.c (line
> > if (G_strcasecmp (old,new) == 0) return 1;
> > If you comment this out and recompile the lib and the command, it works.
> > No idea why this is there. Unless someone objects, I'll remove that line.
> Actually it is due to:
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/general/manage/lib/do_rename.c.diff?r1=1.6&r2=1.7
> where strcmp was replaced with G_strcasecmp, thus making the compare
> case independent. So, the line should not be removed, but it should
> either be reverted to strcmp, or we need G_strcmp, which doesn't exist
> at this stage AFAICT.
The case insensitivity may have been intentional. What happens if you
try this with vector maps or under windows?
