[GRASS-dev] Re: [GRASS-trac] #7: Location wizard: should predefine
DB connection for new location
GRASS-trac
trac at osgeo.org
Mon Dec 31 18:36:31 EST 2007
#7: Location wizard: should predefine DB connection for new location
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Python | Version: svn-trunk
Resolution: | Keywords:
Comment (by hamish):
As mentioned before, I do not think that the VAR file should be a part of
the default MAPSET folder specification.
see http://thread.gmane.org/gmane.comp.gis.grass.devel/22676
e.g. for users who mainly work with rasters this is unneeded filesystem
noise.
C modules which require a DB to be set should be exiting with an error if
none is found (suggesting to run db.connect). Scripts like v.db.add* can
run that automatically if needed. Any other module bugs can be fixed,
exiting with an error is not much work if that doesn't happen already,
just check a return code.
Since I commented out the auto-set to DBF in 6.3cvs's init.sh 3 months ago
there have been no complaints about the change. This is not done in 6.2
either, no complaints there.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/7#comment:4>
GRASS-trac <http://grass.osgeo.org>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies.
