[GRASS-dev] [bug #5462] (grass) GRASS should support exporting E00
Request Tracker
grass-bugs at intevation.de
Thu Feb 1 21:31:25 EST 2007
this bug's URL: http://intevation.de/rt/webrt?serial_num=5462
Subject: GRASS should support exporting E00
Platform: WindowsNT/2000/XP
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.2
Please enter your name and error description here. Don't write general statements such as "this could be better" - please explain in
details how a certain problem can be solved or a feature be added/improved. Send different report for different problems. Thanks!
Dear GRASS Development Team
I have been using GRASS in native window-Cygwin since 2000. In
Thailand, many agencies use ESRI'software such as Arc/Info, Arc View
Program. Also, the Arc-Node-Topology are be influenced the data model
âCoverage that have Topology. I try export data from GRASS into shape
file and import into Arc View: Topology generated in GRASS is not
found in Arc View table.
It is possible that GRASS will be support v.out.e00 in the next
version.Infact, I am using both arc/info and grass, So, I demand GRASS version
6.0 supporting export e.00 format (V.out.e00), because I can exchange
GIS data between agencies in Thailand that mostly use arc/info.
Best Regards
Boonlue Kachenchart
Boonlue Kachenchart : Lecturer
Faculty of Environment and Resource Studies,
Mahidol University,
999 Phuttamonthon Road, Salaya, Phuttamonthon, Nakhon Pathom 73170, Thailand
Phone +66-2441-5000 ext 141, +669-7714510 Fax +66-2441-9509-10
-------------------------------------------- Managed by Request Tracker
