[GRASS-dev] Re: winGRASS
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Feb 7 07:20:04 EST 2007
Hello Michael
If you use the --with-opengl=aqua configure option then nviz will use the
aqua Tcl/Tk, but I thought that was desired?
See William's comments here:
http://grass.itc.it/pipermail/grass-dev/2006-November/027480.html
Perhaps William just compiled his in the brief period while it was
working, and now it is no longer working again?
Just an idea
Paul
On Tue, 6 Feb 2007, Michael Barton wrote:
> I have a problem like this on versions of GRASS that I compile myself on my
> Mac. It doesn't happen on versions that William Kyngesbury compiles. In my
> case, all of GRASS is correctly compiling against an x11 tcltk that I
> specify, but nviz insists on compiling against an aqua version also on my
> machine. It creates a bad nviz binary file (the one that Bob's script
> calls). I can substitute one that William compiles and all is well. Maybe
> something similar is happening to you?
> Michael
> On 2/6/07 5:39 PM, "Paul Kelly" <paul-grass at stjohnspoint.co.uk> wrote:
>> Another outstanding issue is Nviz. It was working on Windows for a while
>> (looked great with Michael's new user interface improvements) but since
>> Bob changed it back to the script startup rather than running the nviz.exe
>> executable directly it no longer works on Windows. In fact I recently
>> tried to revert those changes and found it still wouldn't work; got stuck
>> at the Please Wait screen. A pity, because there is probably very little
>> needs changed to have it working again.
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
