[GRASS-dev] Re: v.buffer creates artefact - bug?
Maris Nartiss
maris.gis at gmail.com
Thu Feb 8 02:58:01 EST 2007
Hi Maciej,
I imported both ascii snippets with v.in.ascii -n format=standard and
they looked like same. Created buffer with size=1 and type=area.
Results where same as in my previous tests. For first ascii snippet, I
got shrinked vector area (like removed vector from inside of area)
plus the mystic circle in middle. Second one - good order - worked as
expected - I got correct buffer.
It seems, that v.buffer expects some features to be in right
order(tm). Next thing to find is it v.buffer specific or it's a design
failure in V_lib. As I wrote already, v.* code is a bit more complex
than I can understand - no help form me, just testing.
I will recompile my GRASS too with -g CFLAG and repeat test. If result
will differ, I will report.
Maris.
2007/2/7, Maciej Sieczka <tutey at o2.pl>:
> Maris,
> Maris Nartiss wrote:
> > Hi all,
> > I was palying a bit with bug-trigering vector and You can see results
> > in attachments - setting buffer to 10m will give different buffer top,
> > setting buffer to 1 m will return more annoying result and stopping
> > buffer process before clean is visible in third image.
> > I also looked in v.buffer code, but my C skeelz are too lame to
> > undrstand it, but I noticed lot of comments with "TODO" and "Should
> > work like this". Also there is some stuff relaying on asumption, thath
> > some stuff is listed clockwise or counterclockwise, etc.
> I suppose this last thing might matter. Please note that the following
> ASCII vector is buffered bad (it's the one you have already tested, the
> infamous ditch_1205):
> B 4
> 600727.68682251 5677973.32091602
> 600739.16582305 5678137.49568095
> 600736.32863997 5678140.4618269
> 600730.63832718 5678056.67823368
> B 2
> 600725.02385533 5677974.01131491
> C 1 1
> 600730.04890192 5678035.56666655
> 1 1205
> B 2
> While it's slightly different version (same coordinates, but a
> different order of vertices - it's well visible in meld/kdif/xdiff) is
> buffered fine.
> B 2
> C 1 1
> 1 1205
> B 2
> B 4
> Can you try that?
> > 2007/2/5, Hamish <hamish_nospam at yahoo.com>:
> >> This probably isn't it, but I use CFLAGS="-g" to compile in debug info,
> >> which I think has the side effect of initing all memory to 0's which
> >> changes the expression of some memory bugs.
> I will try that tomorrow anyway. Who knows.
> Maciek
