[GRASS-dev] v.digit: Could not set Tcl system encoding fixed
Markus Neteler
neteler at itc.it
Thu Feb 8 09:43:02 EST 2007
Glynn Clements wrote on 02/08/2007 12:41 PM:
> Markus Neteler wrote:
>>>> Roberto Flor and me have fixed the bug
>>>> "v.digit: Could not set Tcl system encoding"
>>>> http://intevation.de/rt/webrt?serial_num=4110
>>>> Please test. I'll backport it to 6.2.x then.
>>>> Note: For mysterious Tcl (?) reasons I cannot set iso8859-1 and iso8859-2
>>>> but utf-8, iso8859-15, iso2210-jp, koi8-r, euc-jp etc work.
>>>> Maybe my installation...
>>> I confirm. Same happens on my instalation. tcl/tk 8.4.12, Ubuntu Dapper
>>> 32bit.
>> So we are happy since most of the encodings now work.
> Not having ISO-8859-1 working is a pretty major issue.
I am still not sure if it is a local problem or a general one or depends
on the tcltk version.
> Can you provide more details, preferably including a recipe to
> reproduce the issue using either spearfish or a new location?
Sure (eg Spearfish):
d.mon x0
v.digit -n newmap
# now go to "Settings" icon, "Table" tab, "Add column", add a column of
your choice, "Create table"
# close the "Settings" window
# digitize a line
# enter a value into the attribute popup form
# "submit button" (default is utf-8 which seems to work)
# change the encoding, click "submit button" again and voila' the error
appear in the terminal
Markus
