[GRASS-dev] Re: gis.m: error message when trying to add layer without open map display
Michael Barton michael.barton at asu.edu
Thu Feb 8 13:37:12 EST 2007
Fixed in the cvs.
Michael
On 2/8/07 9:11 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> On 08/02/07 17:00, Michael Barton wrote:
>> Moritz,
>> I'll try to see what's going on with this. It probably has to do with the
>> necessary link between a layer tree and a display. A better error message
>> would likely be "You need to open a display before adding map layers"
> yes, definitely better.
> Thanks !
> Moritz
>> Michael
>> On 2/8/07 6:11 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
>>> Michael,
>>> Since you have been busy working on error catching in gis.m: I've always
>>> found that the error that occurs when you try to add a layer even though
>>> there is no open map display quite difficult to understand for newbies:
>>> invalid command name ".mainframe.frame.pw1.f0.frame.pgs.fpage_1.sw.tree_1"
>>>      while executing
>>> "$tree($mon) selection get"
>>>      (procedure "GmTree::add" line 11)
>>>      invoked from within
>>> "GmTree::add vector"
>>>      ("uplevel" body line 1)
>>>      invoked from within
>>> "uplevel \#0 $cmd"
>>>      (procedure "Button::_release" line 18)
>>>      invoked from within
>>> "Button::_release .mainframe.topf.tb0.bbox2.b0"
>>>      (command bound to event)
>>> Would it be possible to catch this and produce a nicer error message
>>> such as: "You need to open a map display first." ?
>>> Moritz
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics and Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
phone: 480-965-6213
fax: 480-965-7671
