[GRASS-dev] r.gwflow and r3.gwflow compile errors
Scott Mitchell
smitch at mac.com
Thu Feb 8 17:12:17 EST 2007
On 8 Feb 2007, at 17:03, Soeren Gebbert wrote:
> Hi,
> it looks like the linker is not able to find the new gpde library.
> Maybe the lib was not build?
I have object files in the lib/gpde/OBJ.i686-pc-linux-gnu/
directory, but nothing with gpde in the name in dist.i686-pc-linux-
gnu/lib
> I will try to reproduce and fix this.
> Maybe i should remove the new modules from the Makefiles .... .
> Regards
> Soeren
> Am Donnerstag, 8. Februar 2007 22:44 schrieb Scott Mitchell:
>> I just updated my grass6-cvs to check out the r.li - but two other
>> modules didn't compile, the new gwflow.
>> [smitch at gracilis r.gwflow]$ make
>> gcc -L/fc2root/home/smitch/src/cvsgrass/grass6/dist.i686-pc-linux-
>> gnu/
>> lib -Wl,--export-dynamic -Wl,-rpath-link,/fc2root/home/smitch/src/
>> cvsgrass/grass6/dist.i686-pc-linux-gnu/lib -DPACKAGE=
>> \""grassmods"\" -o /fc2root/home/smitch/src/cvsgrass/grass6/
>> dist.i686-
>> pc-linux-gnu/bin/r.gwflow OBJ.i686-pc-linux-gnu/main.o -lgrass_gis -
>> lgrass_datetime -lz -lm -lz
>> OBJ.i686-pc-linux-gnu/main.o: In function `create_solve_les':
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:503:
>> undefined reference to `N_assemble_les_2d'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:514:
>> undefined reference to `N_solver_bicgstab'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:517:
>> undefined reference to `N_solver_lu'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:511:
>> undefined reference to `N_solver_cg'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:520:
>> undefined reference to `N_solver_gauss'
>> OBJ.i686-pc-linux-gnu/main.o: In function `copy_result':
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:484:
>> undefined reference to `N_put_array_2d_value_dcell'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:468:
>> undefined reference to `N_get_array_2d_value_dcell'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:477:
>> OBJ.i686-pc-linux-gnu/main.o: In function `write_result':
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:431:
>> OBJ.i686-pc-linux-gnu/main.o: In function `fill_array_2d':
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:387:
>> OBJ.i686-pc-linux-gnu/main.o: In function `main':
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:215:
>> undefined reference to `N_alloc_geom_data'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:225:
>> undefined reference to `N_alloc_les_callback_2d'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:226:
>> undefined reference to `N_callback_gwflow_2d'
>> undefined reference to `N_set_les_callback_2d_func'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:229:
>> undefined reference to `N_alloc_gwflow_data2d'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:326:
>> undefined reference to `N_free_les'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:328:
>> undefined reference to `N_free_gwflow_data2d'
>> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:290:
>> collect2: ld returned 1 exit status
>> make: *** [/fc2root/home/smitch/src/cvsgrass/grass6/dist.i686-pc-
>> linux-gnu/bin/r.gwflow] Error 1
>> Same general problem in the 3D version. I do have the header files
>> for these functions, as far as I can tell.
>> Does this look familiar to anyone? Suggestions?
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
