[GRASS-dev] r.gwflow and r3.gwflow compile errors
Hamish
hamish_nospam at yahoo.com
Thu Feb 8 20:20:21 EST 2007
Soeren Gebbert wrote:
> it looks like the linker is not able to find the new gpde library.
> Maybe the lib was not build?
> I will try to reproduce and fix this.
They build fine for me. Scott, did you run "make distclean" before
rebuilding from the latest CVS?
> Maybe i should remove the new modules from the Makefiles .... .
The development version is allowed to be broken as long as someone is
actively working on the problem.
Hamish
