[bug #5488] (grass) Re: [GRASS-dev] v.digit: Could not set Tcl system
encoding fixed (bug #4110)
Request Tracker
grass-bugs at intevation.de
Fri Feb 9 03:10:30 EST 2007
this bug's URL: http://intevation.de/rt/webrt?serial_num=5488
Glynn Clements wrote on 02/08/2007 11:38 PM:
> Markus Neteler wrote:
>>>>>> Roberto Flor and me have fixed the bug
>>>>>> "v.digit: Could not set Tcl system encoding"
>>>>>> http://intevation.de/rt/webrt?serial_num=4110
>>>>>> Please test. I'll backport it to 6.2.x then.
>>>>>> Note: For mysterious Tcl (?) reasons I cannot set iso8859-1 and iso8859-2
>>>>>> but utf-8, iso8859-15, iso2210-jp, koi8-r, euc-jp etc work.
>>>>>> Maybe my installation...
>>>>> I confirm. Same happens on my instalation. tcl/tk 8.4.12, Ubuntu Dapper
>>>>> 32bit.
>>>> So we are happy since most of the encodings now work.
>>> Not having ISO-8859-1 working is a pretty major issue.
>> I am still not sure if it is a local problem or a general one or depends
>> on the tcltk version.
>>> Can you provide more details, preferably including a recipe to
>>> reproduce the issue using either spearfish or a new location?
>> Sure (eg Spearfish):
>> d.mon x0
>> v.digit -n newmap
>> # now go to "Settings" icon, "Table" tab, "Add column", add a column of
>> your choice, "Create table"
>> # close the "Settings" window
>> # digitize a line
>> # enter a value into the attribute popup form
>> # "submit button" (default is utf-8 which seems to work)
>> # change the encoding, click "submit button" again and voila' the error
>> appear in the terminal
> Okay.
> I'm pretty sure that the problem is that lib/form/form.c doesn't call
> Tcl_Main(), so the library path doesn't get set, so Tcl can't find its
> .enc files.
> Realistically, if you are trying to use Tcl/Tk and your program
> *doesn't* look very much like tkAppInit.c, all bets are off.
> Rather than trying to process the data from the form library in C,
> form.c should just register the commands then do the rest in Tcl.
Since I know nothing about tcl, I'll leave that to the experts. AFAIK
form.c was
originally written by Radim.
Markus
--- Headers Follow ---
>From neteler at itc.it Fri Feb 9 09:10:29 2007
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from kolab.intevation.de (salmakis.hq.intevation.de [192.168.11.9])
by lists.intevation.de (Postfix) with ESMTP id 9EABF1006CB
for <grass-bugs at lists.intevation.de>; Fri, 9 Feb 2007 09:10:29 +0100 (CET)
Received: from localhost (localhost.localdomain [127.0.0.1])
by kolab.intevation.de (Postfix) with ESMTP id 7A154109397
by kolab.intevation.de (Postfix) with ESMTP id 1F67D10AD0B
Received: from lancelot.itc.it (ns.itc.it [217.77.80.3])
by kolab.intevation.de (Postfix) with ESMTP id E7FC0109397
for <grass-bugs at intevation.de>; Fri, 9 Feb 2007 09:10:27 +0100 (CET)
Received: from lancelot (unknown [127.0.0.1])
by lancelot.itc.it (Symantec Mail Security) with ESMTP id 7F9E638C215
X-AuditID: d94d5003-aed5bbb0000004c3-db-45cc2c73af88
Message-ID: <45CC2C73.5030206 at itc.it>
Date: Fri, 09 Feb 2007 09:10:27 +0100
User-Agent: Thunderbird 1.5.0.9 (X11/20061206)
MIME-Version: 1.0
To: Glynn Clements <glynn at gclements.plus.com>
Cc: grass developers list <grass-dev at grass.itc.it>,
Request Tracker <grass-bugs at intevation.de>
Subject: Re: [GRASS-dev] v.digit: Could not set Tcl system encoding fixed
(bug #4110)
References: <45C9995E.7010700 at itc.it> <45C9F585.30406 at o2.pl> <45CAD4F8.5050400 at itc.it> <17867.3200.384675.355130 at cerise.gclements.plus.com> <45CB36F6.1070906 at itc.it> <17867.42607.267308.193576 at cerise.gclements.plus.com>
In-Reply-To: <17867.42607.267308.193576 at cerise.gclements.plus.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 7bit
X-OriginalArrivalTime: 09 Feb 2007 08:10:27.0211 (UTC) FILETIME=[C1C84DB0:01C74C21]
X-Brightmail-Tracker: AAAAAA==
X-Virus-Scanned: by amavisd-new at intevation.de
X-Spam-Status: No, hits=-5 tagged_above=-999 required=3 tests=[BAYES_00=-5]
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
