[GRASS-dev] r.gwflow and r3.gwflow compile errors
Scott Mitchell
smitch at mac.com
Fri Feb 9 09:23:41 EST 2007
Ah, yes, I forgot that one, sorry. I only did make clean. I blame
the head cold ;) Rebuilding...
Sure enough, fixed. Thanks, all!
Scott
On 9 Feb 2007, at 03:08, Markus Neteler wrote:
> Hamish wrote on 02/09/2007 02:20 AM:
>> Soeren Gebbert wrote:
>>> it looks like the linker is not able to find the new gpde library.
>>> Maybe the lib was not build?
>>> I will try to reproduce and fix this.
>> They build fine for me. Scott, did you run "make distclean" before
>> rebuilding from the latest CVS?
> Right, this is needed since the initial "make" step after "configure"
> copies some include files into the right place.
> I got into the same trap first, then remembered
> "if in doubt, run'make distclean'"
> which solved the problem. I have compiled it successfully on 32 and
> 64bit machines.
> Markus
