[GRASS-dev] [grass-code patches][277] label and color support for
v.to.rast
grass-codepatches at wald.intevation.org
Fri Feb 9 18:17:36 EST 2007
code patches item #277, was opened at 2007-02-10 00:17
Status: Open
Priority: 3
Submitted By: Jachym Cepicky (jachym)
Assigned to: Nobody (None)
Summary: label and color support for v.to.rast
Patch status: None
Patch type: enhancement
GRASS component: vector
GRASS version: CVS HEAD
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
This patch adds two flags and two options to v.to.rast:
-l
-a
rgb_column
label_column
Color and label of raster map categories can be set from vector attribute table.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=205&aid=277&group_id=21
