[GRASS-dev] v.digit: Could not set Tcl system encoding fixed (bug #4110)
Sat Feb 10 09:59:04 EST 2007
Markus Neteler wrote:
> > I'm pretty sure that the problem is that lib/form/form.c doesn't call
> > Tcl_Main(), so the library path doesn't get set, so Tcl can't find its
> > .enc files.
> > Realistically, if you are trying to use Tcl/Tk and your program
> > *doesn't* look very much like tkAppInit.c, all bets are off.
> > Rather than trying to process the data from the form library in C,
> > form.c should just register the commands then do the rest in Tcl.
> Since I know nothing about tcl, I'll leave that to the experts. AFAIK
> form.c was
> originally written by Radim.
The attached patch appears to work, insofar as v.digit appears to work
as before, minus the encoding errors. OTOH, I know next to nothing
about v.digit (or the vector stuff in general), so it would probably
be a good idea for it to be tested by someone who is familiar with
v.digit.
Essentially, the form utility (lib/form/form.c) has been rewritten as
a typical "extended wish", with the communication with the form
library being performed in Tcl.
Index: lib/form/form.c
RCS file: /grassrepository/grass6/lib/form/form.c,v
retrieving revision 1.17
diff -u -r1.17 form.c
--- lib/form/form.c	6 Feb 2007 11:15:03 -0000	1.17
+++ lib/form/form.c	10 Feb 2007 14:51:52 -0000
@@ -12,12 +12,6 @@
 #include <grass/dbmi.h>
 #include <grass/form.h>
-#ifdef __MINGW32__
-#include <winsock.h>
-#define        F_SETFL         4	/* Set file status flags.  */
-#define        O_NONBLOCK      0x0004	/* Non-blocking I/O.  */
-#endif
 /* Structure to store column names and values */
 typedef struct
@@ -26,21 +20,11 @@
     char *value;
 } COLUMN;
-char *Drvname, *Dbname, *Tblname, *Key;
-COLUMN *Columns = NULL;
-int allocatedRows = 0;			/* allocated space */
-int nRows = 0;
+static char *Drvname, *Dbname, *Tblname, *Key;
-int form_open = 0;
-/* Close form */
-int close_form(ClientData cdata, Tcl_Interp * interp, int argc, char *argv[])
-    G_debug(3, "close_form()");
-    form_open = 0;
-    return TCL_OK;
+static COLUMN *Columns = NULL;
+static int allocatedRows = 0;			/* allocated space */
+static int nRows = 0;
 /* Start new sql update */
 int reset_values(ClientData cdata, Tcl_Interp * interp, int argc, char *argv[])
@@ -267,151 +251,49 @@
  *  Form
-int main(int argc, char *argv[])
+int Tcl_AppInit(Tcl_Interp *interp)
-    int length;
-    int ret;
-    char buf[5000];
-    char *child_html, *child_title;
-    static FILE *child_send, *child_recv;
-    static Tcl_Interp *interp;
-    static int frmid = 0;
-    char *encoding_val;
-    G_gisinit("form");
-    G_debug(2, "Form: main()");
-    setlocale(LC_CTYPE, "");
-    child_recv = stdin;
-    child_send = stdout;
-    while (1) {
-	fd_set waitset;
-	struct timeval tv;
-	tv.tv_sec = 0;
-	tv.tv_usec = 200;
-	FD_ZERO(&waitset);
-	FD_SET(fileno(stdin), &waitset);
-	if (select(FD_SETSIZE, &waitset, NULL, NULL, &tv) < 0) {
-	    perror("form: select");
-	ret = read(fileno(stdin), &(buf[0]), 1);
-#ifndef __MINGW32__
-	fcntl(fileno(child_recv), F_SETFL, O_NONBLOCK);	/* Don't wait if pipe is empty */
-#endif
-	if (ret == 0)
-	    break;		/* Pipe was closed by parent -> quit */
-	if (ret == 1) {
-	    G_debug(3, "Form: received = '%c'", buf[0]);
-	    if (buf[0] == 'O') {
-		if (!form_open) {
-		    G_debug(3, "Form is not opened");
-		    /* Open the window and display the form */
-		    interp = Tcl_CreateInterp();
-		    if (Tcl_Init(interp) == TCL_ERROR)
-			G_fatal_error("Tcl_Init failed: %s\n", interp->result);
-		    if (Tk_Init(interp) == TCL_ERROR)
-			G_fatal_error("Tk_Init failed: %s\n", interp->result);
-		    Tcl_CreateCommand(interp, "submit", (Tcl_CmdProc *) submit,
-				      (ClientData) NULL,
-				      (Tcl_CmdDeleteProc *) NULL);
-		    Tcl_CreateCommand(interp, "set_value",
-				      (Tcl_CmdProc *) set_value,
-		    Tcl_CreateCommand(interp, "reset_values",
-				      (Tcl_CmdProc *) reset_values,
-		    Tcl_CreateCommand(interp, "close_form",
-				      (Tcl_CmdProc *) close_form,
-		    sprintf(buf, "%s/etc/form/form.tcl", G_gisbase());
-		    ret = Tcl_EvalFile(interp, buf);
-		    if (ret == TCL_ERROR) {
-			if (interp->result != NULL)
-			    G_fatal_error("Cannot open form: %s\n",
-					  interp->result);
-			else
-			    G_fatal_error("Cannot open form\n");
+	if (Tcl_Init(interp) == TCL_ERROR)
+		return TCL_ERROR;
+	if (Tk_Init(interp) == TCL_ERROR)
+		return TCL_ERROR;
-		    form_open = 1;
-		G_debug(2, "Open form %d", frmid);
-		/* Read title */
-		fgets(buf, 1000, child_recv);
-		length = atoi(buf);	/* length of the string */
-		G_debug(2, "length = %d", length);
-		child_title = (char *)G_malloc(length + 1);
-		fread(child_title, length, 1, child_recv);
-		child_title[length] = '\0';
-		/* Read html */
-		child_html = (char *)G_malloc(length + 1);
-		fread(child_html, length, 1, child_recv);
-		child_html[length] = '\0';
-		memset(buf, '\0', strlen(buf));
-		encoding_val = G__getenv("GRASS_DB_ENCODING");
-		Tcl_ExternalToUtf(interp,
-				  Tcl_GetEncoding(interp, encoding_val),
-				  child_html, strlen(child_html), 0, NULL,
-				  buf, strlen(child_html) * 2, NULL, NULL,
-				  NULL);
-		G_debug(3, "Current GRASS_DB_ENCODING: %s", encoding_val);
-		if (Tcl_SetSystemEncoding(interp, encoding_val) == TCL_ERROR) {
-		    fprintf(stderr,
-			    "Could not set Tcl system encoding to %s\n",
-			    encoding_val);
+	Tcl_StaticPackage(interp, "Tk", Tk_Init, Tk_SafeInit);
-		G_debug(2, "Form: html = %s", buf);
+	 * Call Tcl_CreateCommand for application-specific commands, if
+	 * they weren't already created by the init procedures called above.
+	Tcl_CreateCommand(interp, "submit", (Tcl_CmdProc *) submit,
+			  (ClientData) NULL,
+			  (Tcl_CmdDeleteProc *) NULL);
+	Tcl_CreateCommand(interp, "set_value",
+			  (Tcl_CmdProc *) set_value,
+	Tcl_CreateCommand(interp, "reset_values",
+			  (Tcl_CmdProc *) reset_values,
+	 * Specify a user-specific startup file to invoke if the application
+	 * is run interactively.  Typically the startup file is "~/.apprc"
+	 * where "app" is the name of the application.  If this line is deleted
+	 * then no user-specific startup file will be run under any conditions.
-		/* Insert new page */
-		Tcl_SetVar(interp, "html", buf, 0);
-		sprintf(buf, "add_form %d \"%s\"", frmid, child_title);
-		Tcl_Eval(interp, buf);
-		fprintf(child_send, "O");	/* OK */
-		fflush(child_send);
-		frmid++;
-		G_debug(2, "Form displayed\n");
-	    else if (buf[0] == 'C') {	/* clear old forms */
-		Tcl_Eval(interp, "clear_nb");
-	    else if (buf[0] == 'D') {	/* done! */
-		break;
-	Tcl_Eval(interp, "update");
+	Tcl_SetVar(interp, "tcl_rcFileName", "~/.grassformrc", TCL_GLOBAL_ONLY);
+	return TCL_OK;
-    Tcl_Eval(interp, "destroy .");
-    G_debug(3, "Form: end\n");
-    exit(0);
+int main(int argc, char *argv[])
+	G_gisinit("form");
+	G_debug(2, "Form: main()");
-    return 0;
+	Tk_Main(argc, argv, Tcl_AppInit);
+	return 0;
Index: lib/form/form.tcl
RCS file: /grassrepository/grass6/lib/form/form.tcl,v
retrieving revision 1.3
diff -u -r1.3 form.tcl
--- lib/form/form.tcl	17 Feb 2003 06:41:03 -0000	1.3
+++ lib/form/form.tcl	10 Feb 2007 14:51:52 -0000
@@ -2,17 +2,9 @@
 package require -exact BWidget 1.2.1
 #package require http
-set formpath $env(GISBASE)/etc/form/
+set formpath $env(GISBASE)/etc/form
 source $formpath/html_library.tcl
-set submit_result ""
-set submit_msg ""
-set html ""
-set nb [NoteBook .nb]
-$nb configure -width 300 -height 500
-pack .nb -fill both -expand yes
 proc create_submit_msg { formid  }  {
     global submit_result submit_msg formf
@@ -70,4 +62,97 @@
     create_submit_msg $formid
+proc make_form {} {
+	global nb
+	set nb [NoteBook .nb]
+	$nb configure -width 300 -height 500
+	pack .nb -fill both -expand yes
+proc close_form {} {
+	global form_open
+	wm withdraw .
+	set form_open false
+proc process_command {} {
+	global env
+	global child_recv child_send
+	global form_open encoding_val frmid
+	global html
+	if {[eof $child_recv]} {
+		exit 0
+	set cmd [read $child_recv 1]
+	switch $cmd {
+		O {
+			if {! $form_open} {
+				wm state . normal
+				set form_open true
+			#  Read title
+			set length [gets $child_recv]
+			set child_title [read $child_recv $length]
+			#  Read html
+			set child_html [read $child_recv $length]
+			set child_html [encoding convertfrom $encoding_val $child_html]
+			#  Insert new page
+			set html $child_html
+			add_form $frmid $child_title
+			puts -nonewline $child_send O
+			flush $child_send
+			incr frmid
+		C {	#  clear old forms
+			clear_nb
+			flush $child_send
+		D {	#  done!
+			clear_nb
+			flush $child_send
+			destroy .
+			exit 0
+make_form
+wm protocol . WM_DELETE_WINDOW close_form
 bind . <Destroy> { if { "%W" == "."} { close_form } }
+set submit_result ""
+set submit_msg ""
+set html ""
+set frmid 0
+set form_open true
+set child_recv stdin
+set child_send stdout
+set encoding_val [exec g.gisenv GRASS_DB_ENCODING]
+if {$encoding_val == ""} {
+	set encoding_val [encoding system]
+if {[catch {encoding system $encoding_val}]} {
+	puts stderr "Could not set Tcl system encoding to $encoding_val"
+fconfigure $child_recv -buffering none -encoding binary -translation binary
+fileevent $child_recv readable process_command
Index: lib/form/open.c
RCS file: /grassrepository/grass6/lib/form/open.c,v
retrieving revision 1.13
diff -u -r1.13 open.c
--- lib/form/open.c	7 Nov 2006 06:05:07 -0000	1.13
+++ lib/form/open.c	10 Feb 2007 14:51:52 -0000
@@ -51,9 +51,6 @@
 #endif /*USE_G_SOCKS*/
     int        length;
     /* child */
-    char        buf[2000];
     G_debug ( 2, "F_open(): title = %s", title);
@@ -70,6 +67,8 @@
     if ( pid == 0 ) { /* Child */
+	char command[2000], script[2000];
         G_debug ( 2, "CHILD" );
         /* Note: If you are forking in a Tk based apllication  you
@@ -94,9 +93,10 @@
-	sprintf(buf,"%s/etc/form/form", G_gisbase());
+	sprintf(command, "%s/etc/form/form", G_gisbase());
+	sprintf(script,  "%s/etc/form/form.tcl", G_gisbase());
-	execl ("/bin/sh", "sh", "-c", buf, NULL);
+	execl(command, "form", "-f", script, NULL);
 	G_debug(2, "CHILD END\n");
 	exit (0);
