[GRASS-dev] d.text vs d.text.freetype vs d.text.new
Glynn Clements
glynn at gclements.plus.com
Sat Feb 10 20:40:35 EST 2007
Markus Neteler wrote:
> while starting to write up the changes in GRASS 6.3 for
> an upcoming 6.3.0 release, I found that we have
> d.text
> d.text.freetype
> d.text.new
> What is the state of d.text.new?
AFAICT, it's essentially a superset of the other two.
Although it lacks the charset=, path= and -c switches from
d.text.freetype, that functionality is available through other means
(-c is implied if text= isn't used, the encoding and path can be set
in the freetypecap file or via d.font[.freetype]).
