[GRASS-dev] [grass-code issues][282] Label size fixed in dialog
grass-codeissues at wald.intevation.org
Sun Feb 11 06:59:29 EST 2007
code issues item #282, was opened at 2007-02-11 12:59
Status: Open
Priority: 3
Submitted By: Carlos Dávila (carluti)
Assigned to: Nobody (None)
Summary: Label size fixed in dialog
Issue type: None
Issue status: None
GRASS version: CVS HEAD
GRASS component: GUI other
Operating system: Linux
Operating system version: debian testing 2.6.18-3-486
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
Last label in the dialog "Define location using EPSG projection codes" from "GRASS Startup" has a fixed size, so that message appear cut in some languages when it's longer than English original one.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=282&group_id=21
