In the bug tracker view, can the default "Assignee:" field be set to "Any" instead of "Unassigned"? ie currently you only see new bugs, not all open bugs unless you submit a new custom query. someone browsing for a bug won't know that it is missing from the list as it has already been taken by <>. ? thanks, Hamish
