[GRASS-dev] G_point_in_region() ?
Brad Douglas
rez at touchofmadness.com
Tue Feb 13 21:48:23 EST 2007
On Wed, 2007-02-14 at 14:23 +1300, Hamish wrote:
> a C question:
> if (FALSE && G_something())
> will stop as soon as it tests the first term (FALSE) and won't execute
> G_something(), does OR work the same way?
These days, that may be up to the compiler (tunable?). Some
architectures offer parallel branching that would execute both
simultaneously and compare results. Glynn would know more details.
For the above to continue into the if branch, both variables must return
a value >= 1. ANSI C specifies that order of operation is guaranteed
left to right for '||', '&&', and '?:'.
In short, if the left-hand expression is 'false', the right-hand
expression will not be executed.
> if(TRUE || G_something())
> is there a chance G_somthing() will get run in the OR case?
> (the first term will know if the G_() call will be valid)
See above.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
