[bug #5496] (grass) Re: [GRASS-dev] v.digit: Could not set Tcl system encoding fixed (bug #4110)
Request Tracker grass-bugs at intevation.de
Thu Feb 15 16:00:21 EST 2007
this bug's URL: http://intevation.de/rt/webrt?serial_num=5496
Glynn Clements wrote:
> > > I'm pretty sure that the problem is that lib/form/form.c doesn't call
> > > Tcl_Main(), so the library path doesn't get set, so Tcl can't find its
> > > .enc files.
> > > Realistically, if you are trying to use Tcl/Tk and your program
> > > *doesn't* look very much like tkAppInit.c, all bets are off.
> > > Rather than trying to process the data from the form library in C,
> > > form.c should just register the commands then do the rest in Tcl.
> > Since I know nothing about tcl, I'll leave that to the experts. AFAIK
> > form.c was
> > originally written by Radim.
> The attached patch appears to work, insofar as v.digit appears to work
> as before, minus the encoding errors. OTOH, I know next to nothing
> about v.digit (or the vector stuff in general), so it would probably
> be a good idea for it to be tested by someone who is familiar with
> v.digit.
> Essentially, the form utility (lib/form/form.c) has been rewritten as
> a typical "extended wish", with the communication with the form
> library being performed in Tcl.
As I haven't had any response either way on this, I've committed the
changes.
--- Headers Follow ---
>From glynn at gclements.plus.com  Thu Feb 15 22:00:21 2007
Return-Path: <glynn at gclements.plus.com>
Delivered-To: grass-bugs at lists.intevation.de
Received: from kolab.intevation.de (salmakis.hq.intevation.de [192.168.11.9])
	by lists.intevation.de (Postfix) with ESMTP id 18D19101EE8
	for <grass-bugs at lists.intevation.de>; Thu, 15 Feb 2007 22:00:21 +0100 (CET)
Received: from localhost (localhost.localdomain [127.0.0.1])
	by kolab.intevation.de (Postfix) with ESMTP id 0480914B75CE
	by kolab.intevation.de (Postfix) with ESMTP id 9FC2214B75CD
	for <grass-bugs at lists.intevation.de>; Thu, 15 Feb 2007 22:00:19 +0100 (CET)
Received: from cerise.gclements.plus.com (82-71-30-52.dsl.in-addr.zen.co.uk [82.71.30.52])
	by kolab.intevation.de (Postfix) with ESMTP id 69C0314B75CB
	for <grass-bugs at intevation.de>; Thu, 15 Feb 2007 22:00:19 +0100 (CET)
Received: from cerise.gclements.plus.com (localhost [127.0.0.1])
	by cerise.gclements.plus.com (8.13.7/8.13.7) with ESMTP id l1FL0HcX018944;
	Thu, 15 Feb 2007 21:00:17 GMT
Received: (from glynn at localhost)
	by cerise.gclements.plus.com (8.13.7/8.13.7/Submit) id l1FL0HXq018941;
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Message-ID: <17876.51681.722004.212265 at cerise.gclements.plus.com>
Date: Thu, 15 Feb 2007 21:00:17 +0000
To: Markus Neteler <neteler at itc.it>,
	Request Tracker <grass-bugs at intevation.de>,
	grass developers list <grass-dev at grass.itc.it>
Subject: Re: [GRASS-dev] v.digit: Could not set Tcl system encoding fixed
	(bug #4110)
In-Reply-To: <17869.56760.385929.175604 at cerise.gclements.plus.com>
References: <45C9995E.7010700 at itc.it>
	<45C9F585.30406 at o2.pl>
	<45CAD4F8.5050400 at itc.it>
	<17867.3200.384675.355130 at cerise.gclements.plus.com>
	<45CB36F6.1070906 at itc.it>
	<17867.42607.267308.193576 at cerise.gclements.plus.com>
	<45CC2C73.5030206 at itc.it>
X-Mailer: VM 7.07 under 21.4 (patch 20) "Double Solitaire" XEmacs Lucid
X-Virus-Scanned: by amavisd-new at intevation.de
X-Spam-Status: No, score=-4.665 tagged_above=-999 required=3
 tests=[BAYES_00=-5, DNS_FROM_RFC_ABUSE=0.2, FORGED_RCVD_HELO=0.135]
X-Spam-Score: -4.665
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
