[GRASS-dev] r3.univar
Sören Gebbert
soerengebbert at gmx.de
Sun Feb 18 06:22:46 EST 2007
Hi Paul,
i was thinking about this too, but for a fast functional prototype
i implemented it separately.
Merging is a good idea, i will do it.
Soeren
Paul Kelly schrieb:
> I haven't looked at any of the code, but if as you say it is mostly
> identical to r.univar then perhaps it might be possible to compile
> r.univar and r3.univar from the same directory, as is done for r.mapcalc
> and r3.mapcalc? It would save cloning of code in the source
> distribution, make bugfixes easier - and an easy way for you to share
> that new function.
> Just an idea,
> Paul
> On Sat, 17 Feb 2007, [ISO-8859-15] Sören Gebbert wrote:
>> Hi devs,
>> i have written a new raster3d module named r3.univar.
>> The code is mostly identical with r.univar from Hamish.
>> I have replaced the qsort with a heapsort function,
>> because qsort is in the worst case scenario quite slow on large datasets.
>> Maybe we can put heapsort as library functions into the
>> grass library, so r.univar and other modules can use them too?
>> Or is this function already present in grass?
>> The new module is available here:
>> http://www-pool.math.tu-berlin.de/~soeren/grass/modules/r3.univar.tar.bz2
>> Best regards
>> Soeren
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
