[GRASS-dev] Re: Profiler updates
Michael Barton michael.barton at asu.edu
Mon Feb 19 03:24:14 EST 2007
Hamish,
I implemented all your wishes below. Just committed it to the cvs. See what
you think. I'm to sleep now.
Michael
On 2/13/07 9:47 PM, "Hamish" <hamish_nospam at yahoo.com> wrote:
> Michael wrote:
>> r.profile should simply report NULL values for any coordinates
>> that fall outside the region--like many other tools that return
>> information about raster cells.
> Done in 6.3-cvs. It is too invasive to backport to 6.2, so you should
> still try and figure out why gis.m crashes if r.profile exits with a
> fatal error. (in 6.2-cvs it now fatal errors instead of returning
> incorrect results)
>> This could easily be trapped and dealt with in the profiler.
> Currently the profile line interpolates over areas of null value.
> It would be more correct if the line stopped and then restarted
> when the data resumed. e.g.:
>   http://bambi.otago.ac.nz/hamish/grass/profile_nulls.png
> wish 1: prettify max value on x-axis:
> Index: profile.tcl
> RCS file:
> /home/grass/grassrepository/grass6/gui/tcltk/gis.m/profile.tcl,v
> retrieving revision 1.13
> diff -u -r1.13 profile.tcl
> --- profile.tcl 11 Feb 2007 23:58:53 -0000      1.13
> +++ profile.tcl 14 Feb 2007 04:20:06 -0000
> @@ -494,7 +494,7 @@
>         # add label for total transect distance
>         $pcan create text $right $xscaletop \
> -               -text "$cumdist" \
> +               -text "[format %g $cumdist]" \
>                 -anchor n \
>                 -justify center
> perhaps do the same for x-axis min/max?
>  (are the double-quotes around [] redundant?)
> wish 2: add units to the axes.
> # x-axis: r.profile always return meters
> # y-axis get units (plural) from g.proj:
> g.proj -p | grep '^units' | cut -f2 -d: | awk '{print $1}'
>  * probably want to do that in Tcl not with unix utils :) + rotate 90 deg.
>  * nice example of where Python SWIG interface to libgis will be useful.
>    Instead of running all of g.proj + parsing you could just get the
>    value directly via G_database_unit_name(1). (1==plural)
> wish 3: write distance labels for ticks along the x-axis.
> I'm not sure how to guarantee that they won't overlap if too close
> together.
> also-- the display manager is ignoring the color rule for NULL.
> For that screenshot I had set up color rules like this:
> G63> r.colors elevation.dem col=rules << EOF
> nv red
> 0% green
> 50% yellow
> 100% blue
> EOF
> in a xmon you see the NULL slivers are red, but in the display manager
> they are white.
> Hamish
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
