[GRASS-dev] g.copy rast=
Martin Landa
landa.martin at gmail.com
Mon Feb 19 08:33:29 EST 2007
it is strange, on my machine g.copy works. What does gdb say?
Martin
2007/2/19, Martin Rutzinger <Martin.Rutzinger at uibk.ac.at>:
> hi list,
> with the recent cvs version of grass63 g.copy for raster maps doesn't work any
> more. i just get a meaningless 'memory access error' (speicherzugriffsfehler).
> runinng configure, make, make install gives no error messages.
> g.gisenv set="DEBUG=5"
> g.copy rast=raster1,raster2
> D3/5: Copy rast
> Copy <raster1 at hohenems_site> to current mapset as <raster2>
> Speicherzugriffsfehler
> r.info raster2
> D2/5: G__home home = /home/rusch
> WARNUNG: Kann Header-Datei [raster2 in hohenems_site] nicht öffnen
> WARNUNG: Kategorie Unterstützung für [raster2] im Mapset [hohenems_site]
> missing
> WARNUNG: Kann die History-Informationen der Karte [raster2] in Mapset
> [hohenems_site] nicht finden.
> WARNUNG: Kann range Datei für [raster2 in hohenems_site] nicht lesen.
> FEHLER: Kann die Wertespanne nicht lesen.
> the problem appears on FC4,FC5 and FC6 aswell with following configuration:
> FLAGS='-g -Wall' ./configure --with-x --enable-shared --with-proj
> --with-gdal=/usr/local/bin/gdal-config --with-tcltk-includes=/usr/local/include
> --with-postgres-includes=/usr/local/pgsql/include
> --with-postgres-libs=/usr/local/pgsql/lib
> --with-freetype-includes=/usr/include/freetype2 --with-freetype-libs=/usr/lib
> --enable-largefile --with-odbc --with-motif --with-freetype=yes --with-cxx
> --with-glw --with-nls --with-blas --with-lapack
> --with-lapack-libs=/usr/local/lib --with-ffmpeg
> --with-ffmpeg-includes=/usr/local/include/ffmpeg --with-sqlite
> --with-proj-share=/usr/local/share/proj/ --enable-64bit --with-python
> i don't know which libs/pkg are used by g.copy; but i tried different versions
> of e.g. gdal ( gdal-1.3.2/gdal-1.4.0/gdal-svn; tcl/tk8.5a5/tcl/tk8.4.14) but it
> seems to me that it's not dependent on a certain version of a package.
> thanks alot!
> martin
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
