[GRASS-dev] [bug #5219] (grass) d.vect display=cat works only for layer 1
Martin Landa landa.martin at gmail.com
Mon Feb 19 09:32:49 EST 2007
BTW, it should fix
https://intevation.de/rt/webrt?serial_num=4004
https://intevation.de/rt/webrt?serial_num=5219
I vote for using layer number given by the layer parameter as default
layer number for labels.
Martin
2007/2/19, Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2007/2/19, Hamish <hamish_nospam at yahoo.com>:
> > easier said than done; the parser can't know before hand what the answer
> > to another option will be. but it is possible to give it no default and
> > add to the llayer's option description that it will use the layer= answer
> > if not given. While possible, I'm still not sure if it's advisable. (shrug)
> it could be implemented like this (see the patch) for example. Just I
> am also not sure, maybe it is better for the user to set up the llayer
> according to layer parameter(?)
> Martin
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
