[GRASS-dev] r.flow with barrier fails
Glynn Clements
glynn at gclements.plus.com
Mon Feb 19 13:19:13 EST 2007
J-Báchym Čepický wrote:-A
> Hi, r.flow fails, when used with barrin option:
> r.flow elevin=elevation.dem barin=roads flout=streams
> Reading input files: elevation
> Reading input files: barrier
> Segmentation fault
> that is, because dsout option is not defined and read_input_files()
> (io.c) tryes to store something in ds structure
> when dsout option is defined, you get no reasonable result:
> r.flow elevin=elevation.dem barin=roads flout=streams dsout=density
> d.rast density
> what to do?
Probably this:
--- raster/r.flow/io.c 7 Feb 2007 05:24:40 -0000 1.14
+++ raster/r.flow/io.c 19 Feb 2007 18:18:41 -0000
@@ -126,7 +126,7 @@
for (col = 0; col < region.cols; col++)
BM_set(bitbar, col, row, (barc[col] != 0));
- if (barc[col] != 0)
+ if (ds.buf && barc[col] != 0)
put(ds, row, col, -1);
