[GRASS-dev] g.copy rast=
    Glynn Clements
    glynn at gclements.plus.com
    Mon Feb 19 13:24:36 EST 2007
Martin Rutzinger wrote:
> GRASS 6.3.cvs (utm):~ > gdb `which g.copy`
> (gdb) run "rast=rott_one,test1"
> Starting program: /usr/local/grass-6.3.cvs/bin/g.copy "rast=rott_one,test1"
> [Thread debugging using libthread_db enabled]
> [New Thread -1208944944 (LWP 13355)]
> Copy <rott_one at hohenems_site> to current mapset as <test1>
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread -1208944944 (LWP 13355)]
> do_copy (n=0, old=0xa02b838 "rott_one", mapset=0xa02b870 "hohenems_site",
> new=0xa02b848 "test1") at do_copy.c:40
> 40              for (i = 0; i < list[n].nelem; i++)
> (gdb)
This looks like a problem with $GISBASE/etc/element_list.
