[GRASS-dev] db/drivers/dbf/tables.c contains call to 'mv'
Moritz Lennert mlennert at club.worldonline.be
Tue Feb 20 06:59:12 EST 2007
On lines 313 and 324 db/drivers/dbf/tables.c contains a call to 'mv'. This
fails under Windows as the command cannot be found.
There is a #ifdef __MINGW32__ between the two calls. If this becomes true,
do we still need the mv calls ?
Moritz
