[GRASS-dev] [bug #5219] (grass) d.vect display=cat works only for
layer 1
Martin Landa
landa.martin at gmail.com
Tue Feb 20 08:25:52 EST 2007
I am just not sure about fixing this:
https://intevation.de/rt/webrt?serial_num=4004&display=History
* the changes which I made in CVS have no connection with this bug
* on the other hand, it seems to work OK for me (i.e. I cannot
reproduce described behaviour)
Martin
2007/2/20, Martin Landa <landa.martin at gmail.com>:
> Hi,
> I committed the changes to CVS (I used G_define_option() instead of
> G_define_standard_option()). Closing the bugs/wishes number 4004 and
> 5219.
> Martin
> > Hi,
> > but there is used G_define_standard_option(G_OPT_V_FIELD)
> > (G_define_option() could be used also) which sets answer to "1". Not
> > sure if I understand well.
> > Regards,
> > Martin
> > 2007/2/19, Hamish <hamish_nospam at yahoo.com>:
> > > Martin Landa wrote:
> > > > + lfield_opt->answer = NULL;
> > > Not needed. G_define_option() sets that to null already.
> > > Hamish
> > Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
