[GRASS-dev] g.parser: gisprompt: color-option ?
Tue Feb 20 12:38:14 EST 2007
"Peter Löwe" wrote:
> is there a way to configure a shell-script using
> #%  gisprompt
> to encourage the g.parser module to provide a color selection window (like the ones in d.vect for color/bcolor) ?
> The straightforward approach
> #% gisprompt old,color,color
> does not work.
Use:
	#% gisprompt: color,grass,color
That's what d.vect uses; the GUI only requires that the string begins
with "color," to display a colour selector dialog.
