[GRASS-dev] display/drivers/HTMLMAP status
Moritz Lennert
mlennert at club.worldonline.be
Tue Feb 20 19:37:52 EST 2007
On Wed, February 21, 2007 00:46, Glynn Clements wrote:
> Stand-alone driver,
what do you mean by this ?
> small screen, complex map (many vertices),
> variable region (from the entire map down to a tiny subset). This is
> likely to be the worst case for render=c. That will provide baseline
> values to evaluate the usefulness of particular optimisations.
ok
Moritz
