[GRASS-dev] [grass-code P][308] Window close on startup screen
should exit GRASS
grass-codep at wald.intevation.org
Wed Feb 21 05:47:44 EST 2007
code P item #308, was opened at 2007-02-21 12:47
Status: Open
Priority: 3
Submitted By: Māris Nartišs (marisn)
Assigned to: Michael Barton (michael)
Summary: Window close on startup screen should exit GRASS
Patch status: None
Patch type: fix
GRASS component: startup
GRASS version: CVS HEAD
GRASS CVS checkout date, if applies (YYMMDD): 070221
Initial Comment:
This patch fixes issue, when closing startup screen window it starts GRASS and not exits it.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=205&aid=308&group_id=21
