[GRASS-dev] GRASS-TNG
Michael Barton michael.barton at asu.edu
Wed Feb 21 11:44:01 EST 2007
I'm all for improvements to the GRASS code and for adding new expertise to
the development team. I also think that new open source GIS (and other)
projects are a good thing. Ongoing evolution and diversity are hallmarks of
the open source community.
If there are to be major improvements or restructuring of the GRASS code, it
will benefit more people if it takes place within the (very loose) structure
of the GRASS community and existing code base. For example, Glynn Clements
has put in an enormous amount of work to modernize and update code recently.
He could really use some expert help with this.
If you are starting a completely new GIS project from scratch, this is
great. But giving it the name GRASS is misleading to potential users--even
more so if it has no relationship with the existing project except the name.
IMHO, I wish you would be willing to contribute your expertise to the
existing project, which can always use new developers. However, if you
prefer not to do this and would rather start a new project, I'd prefer that
you named it something other than GRASS to avoid confusion.
Michael
On 2/21/07 8:16 AM, "Radek Bartoň" <xbarto33 at stud.fit.vutbr.cz> wrote:
> On Wednesday 21 of February 2007 15:19:55 Paolo Cavallini wrote:
>> So I assume it is a fork, which is generally a Bad Thing.
>> May I ask you why forking, and which development forces do you have to
>> carry on what appears a daunting task?
>> All the best.
>> pc
> If it is fork depends on what is definition of fork. Generally it should be
> independent project which would provide modern programming framework for
> analytical modules similar to that in current GRASS. So any user which is
> used to work with GRASS command line would be familiar with new system but
> inside it'will use completely new design oriented to OOP, extensibility,
> parallelity and dynamic languages. Theoretically it should be compatible with
> any GRASS's GUI developed over modules in the future.
> IMHO a current state of core parts of GRASS is so unogranizes and oldstyled
> that any progressive development is very difficult. That is why I think that
> start from scratch and only  take good ideas from GRASS is now the best
> solution how to make a 21th century open-source GIS realizable.
> For next one year I'll be working on making its design and prototype
> implementation as my diploma work so even if this project wouldn't keep up it
> would be at least a research of GIS domain. I have spoken with a few current
> GRASS developers and they invite my ideas so I wish it won't happen.
> Only support from comunity I miss for now are discussion of ideas and needs of
> features but any kind of help or invention is welcomed.
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
