[GRASS-dev] Re: v.digit does not start from gis.m
Maris Nartiss maris.gis at gmail.com
Thu Feb 22 16:21:10 EST 2007
Hi Glynn,
Your idea works like charm. Attached it as patch for faster commiting.
Only thing that makes me wonder - that "spawn" call was there since
May 8 2006 [1] - why it was problem only for 6.3? Or noone was using
ever v.digit from gis.m??
Anyway - thanks for saving day (again),
Maris.
[1] http://freegis.org/cgi-bin/viewcvs.cgi/grass6/gui/tcltk/gis.m/runandoutput.tcl.diff?r1=1.6&r2=1.7
2007/2/22, Glynn Clements <glynn at gclements.plus.com>:
> Maciej Sieczka wrote:
> > Maris has submitted a patch with a hack/fix for this issue. Please see
> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=298&group_id=21.
> > It works for me, but it's hackish. Better ideas?
>  	spawn d.mon start=$xmon
> Rather than using "spawn", you could try "exec", but you need to
> redirect the standard descriptors, otherwise exec won't return. E.g.
> (untested):
> 	global devnull
> 	exec d.mon start=$xmon >$devnull 2>$devnull
> Although the d.mon process terminates once the monitor is accepting
> connections, the monitor will inherit the stdout/stderr pipes which
> Tcl's exec command creates, and exec won't return until these are
> closed (it returns the entire output from the command as its result).
> OTOH, I've been re-writing v.digit not to require a monitor, so
> hopefully this issue should soon be moot.
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070222/7e53f918/v.digit.gis.m.bin
