[GRASS-dev] aliases in GRASS
Thu Feb 22 16:42:16 EST 2007
Robert Nuske wrote:
> > > Looking forward to comments about the intention of line 815
> > > in 'grass-6.3.cvs/etc/Init.sh' .
> > Probably someone forgot that $HOME hadn't been reverted at that point.
> > Reverting $PATH and $HOME should probably come first. Actually, I'm
> > not sure that there's any need to mess with $HOME; AFAICT, it was done
> > so that the .bash_history file would get stored in the mapset, but
> > that can be achieved by setting HISTFILE.
> So, am I right that this line is useless in its current state and should be
> changed or taken out?
Yes.
> I would prefer if it would source the .alias in the users home directory.
That's potentically problematic.
If the user puts ". ~/.bashrc" into their ~/.grass.bashrc file, and
their ~/.bashrc sources ~/.alias, then having init.sh source ~/.alias
would result in it getting read twice.
Having Init.sh set up a .bashrc file is one thing (that name is built
into bash), but the ~/.alias file is something that specific
distribution vendors have cooked up for use by their default ~/.bashrc
(etc) scripts. If you aren't using such a platform, ~/.alias might not
even contain bash code.
