[GRASS-dev] testing speed of different vector polygon fill options [was: display/drivers/HTMLMAP status]
Moritz Lennert mlennert at club.worldonline.be
Fri Feb 23 10:02:35 EST 2007
Here's another test run. Script used and result file attached.
File info (from v.build):
Number of nodes     :   67425
Number of primitives:   86425
Number of points    :   0
Number of lines     :   0
Number of boundaries:   65961
Number of centroids :   20464
Number of areas     :   20464
Number of isles     :   1464
Moritz
Type: text/csv
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070223/2b3b14e1/render_test.bin
Type: application/x-shellscript
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070223/2b3b14e1/render_test-0001.bin
