[GRASS-dev] Modules
    Wolf Bergenheim
    wolf at bergenheim.net
    Fri Feb 23 10:23:17 EST 2007
Glynn Clements wrote:
 > IOW, a hybrid Tcl/Tk+C (or Python+C) program will work, but a
 > combination of a pure Tcl/Tk (or Python) program with a pure C helper
 > program won't work.
Not necessarily. When I first started writing v.edit my idea was that
the GUI wold have an internal undo / changes stack, where it would
record what the user has drawn. Then when the user chooses to save his
work, v.edit would be called to commit these changes to the vector file.
That way v.edit the editor doesn't need to build partial topologies,
etc, and that way the GUI doesn't need direct access to the vector
library. The GUI would be mostly a visual drawing tool, and v.edit would
then make sure that everything is topologically correct. Perhaps it's
not a good idea, I don't know, but that was the original idea of how to
use v.edit as a back end. After the save the editor would clear its
change stack and read the vector file (using v.to.ascii, or some other
interface like SWIG).
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
