[GRASS-dev] nviz volume fails: unknown shade style returned in get_drawmode
Fri Feb 23 13:43:44 EST 2007
Markus Neteler wrote:
> > in the recent restructuring of NVIZ the volume
> > was apparently not tested:
> > Dataset (9.3MB):
> >  http://mpa.itc.it/grasstutor/data7/slovakia3d.tar.gz
> > grass63 ~/grassdata/slovakia3d/PERMANENT/
> > nviz el=dem500 vol=precip3d.500z50
> > Loading Data
> > Update elev null mask
> > Loading Data
> > translating colors from fp
> > recalculating normals...
> > Error in startup script: Internal Error: unknown shade style returned in get_drawmode
> >     while executing
> > "Nvol$curr slice get_drawmode"
> The problem is in
> visualization/nviz/src/map_obj.c
> line 833 etc read like this (G_debug() I have added for me only):
>     /* Parse mode returned for shade style and surface style */
>     G_debug(0,"mode: %d",mode);
>     if (mode & DM_GOURAUD)
>     strcpy(shade, "gouraud");
>     else if (mode & DM_FLAT)
>     strcpy(shade, "flat");
>     else {
>     Tcl_SetResult(interp,
>               "Internal Error: unknown shade style returned in get_drawmode",
>               TCL_VOLATILE);
>     return (TCL_ERROR);
> Result is:
> D0/0: mode: 2308
> get_drawmode
>     while executing
> In
> include/gsurf.h
> are definitions for:
> /* surface display modes */
> #define DM_GOURAUD   0x00000100
> #define DM_FLAT      0x00000200   /* defined for symmetry */
> #define DM_FRINGE    0x00000010
> #define DM_WIRE      0x00000001
> #define DM_COL_WIRE  0x00000002
> #define DM_POLY      0x00000004
> #define DM_WIRE_POLY 0x00000008
> #define DM_GRID_WIRE 0x00000400
> #define DM_GRID_SURF 0x00000800
> Not sure what mode = 2308 means...
2308 decimal == 0x904 == DM_GRID_SURF|DM_GOURAUD|DM_POLY
IOW, I have no clue what's going on here.
